i want to change it into .TIFF format on rectifying and saving
3241
04-24-2017 04:44 AM
SHAHIDRAZA1
On rectifying (georefrencing) why i cant edit format of the image?
After
XanderBakker
Esri Esteemed Contributor
Your output location is pointing to the default File GeoDatabase.
If you change it to a folder, you will be able to save as TIFF
XanderBakker
SHAHIDRAZA1
Thanks Xander, i have just started using ArcGIS for my Project work...
i appreciate your help...
Regards.
Shahid Raza
XanderBakker
Glad it worked and that's what the GeoNet community is all about, to learn from each other.
