4x: How to manually place an Expand in its container?
4896
11
04-24-2017 12:53 PM
DirkVandervoort
Occasional Contributor II
   var searchWidget = new Search({
     view: view
   var expand = new Expand({
     expandIconClass: "esri-icon-search",
     view: view,
     content: searchWidget
   view.ui.add(expand, "manual");
By default the Expand gets placed in the upper-left corner, flush with the content of the container. I want to place the Expand someplace else (e.g., flush with the left side of the container, 300px from the top). I assume I can do it in a style, however I cannot create a class and set the location properties of the class.  I can a handle on the element. I can inspect it in the debugger. But I cannot change the location properties of the element.
Any help please. A clue. Anything...
RobertScheitlin__GISP
Dirk,
   I am having a hard time with this as well. If you are only going to use one expand widget then you can simply use this css rule:
.esri-expand {
  left: 20px;
  top: 400px;
But the issue is when you need more than one.
The Widget class says it have a "id" property
The unique ID assigned to the widget when the widget is created
So I though I could assign that and then use a css rule with that id but I never see the id applied to the widget.
Maybe Matt can shead some light on this.
MDriscoll-esristaff
KellyHutchins
Esri Frequent Contributor
If I understand the question correctly this JS Bin should help.
JS Bin - Collaborative JavaScript Debugging
Basically it uses the container property to define a dom node where the expand widget will be rendered.
Edited - see example that uses 'manual' below for a simpler approach.
Kelly,
   Thanks for that code example. I still have a question about the proper use of the view.ui.add(x, "manual"); then. How do you properly use "manual" then?
KellyHutchins
Good question. I missed the 'manual option' in the api ref. So I think this is how you'd use it.
<!DOCTYPE HTML>
<html>
<head>
  <meta charset="utf-8">
  <title>Expand widget - 4.3</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.3/esri/css/main.css">
  <script src="https://js.arcgis.com/4.3/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .esri-ui-manual-container{
      top:300px;
      right:0;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/views/SceneView",
      "esri/widgets/Expand",
      "esri/widgets/BasemapGallery",
      "dojo/domReady!"
    ], function(
      Map, SceneView, Expand, BasemapGallery
      var map = new Map({
        basemap: "satellite"
      var view = new SceneView({
        container: "viewDiv",
        map: map
      // Create a BasemapGallery widget instance and set
      // its container to a div element
      var basemapGallery = new BasemapGallery({
        view: view,
        container: document.createElement("div")
      // Create an Expand instance and set the content
      // property to the DOM node of the basemap gallery widget
      // Use an Esri icon font to represent the content inside
      // of the Expand widget
      var bgExpand = new Expand({
        view: view,
        content: basemapGallery.domNode,
        container: "expandDiv",
        expandIconClass: "esri-icon-basemap"
      // Add the expand instance to the ui
      view.ui.add(bgExpand, "manual");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Sorry to drag this on, but wouldn't that affect all ui element added manually instead of just one particular element?
KellyHutchins
Yes. But I think I'm missing something. If you just want to place one element in a particular location then wouldn't you just position it as shown in the first example?
DirkVandervoort
I'm trying to add multiple Expands, each at their own manual location e.g., right side, left side, top, bottom, etc. These host OOTB widgets and custom widgets we are writing ourselves. Thank you for the input for one element - that solved part of the problem. Any idea how to handle multiple widgets?
Yes that is exactly what I am asking as well, multiple specifically placed ui items.
KellyHutchins
Same as the approach in the first comment I made just create a different div for each and use css to position the expand widget where you'd like. You'll want to take a look at the css for the Expand widget - see link in API ref because in some cases you'll need to add logic to ensure the container doesn't expand off screen.
