HRESULT: 0x8004011 ESIR.Framwork.AppROT
1376
04-25-2017 08:33 AM
LuisAcedo
Hey,
I have an application that we modified from a sample called ArcMap 2 SLD. The application is in VB.NET and it runs as as independent windows outside ArcMap (It is an exe)
On this application the author uses AppROT to get the running ArcMap and obtain the map display. Which it works perfectly. However when I run my modification of his tool, I get an error right on: m_ObjAppROT = New AppROT
The error I get is:
Could not retrieve COM class generator for component with CLSID {FABC30FB-D273-11D2-9F36-00C04F6BC61A} Due to the following error: 80040111 ClassFactory can not supply the requested class
The CLSID is for esriFramework AppROT Key.
The code
Imports ESRI.ArcGIS.Framework
Imports ESRI.ArcGIS.Framework.AppROTClass
Imports System.Runtime.InteropServices
Imports ESRI.ArcGIS.SystemUI
Imports ESRI.ArcGIS.ArcMapUI
Imports ESRI.ArcGIS.Carto
Imports ESRI.ArcGIS.Carto.FeatureLayerClass
Imports ESRI.ArcGIS.Display
Imports stdole
Imports ESRI.ArcGIS.Geodatabase
Imports ESRI.ArcGIS.esriSystem
Imports System.IO
Public Class Analize_ArcMap_Symbols
#Region "Membervariablen"
    Private m_ObjDoc As IMxDocument
    Private m_ObjApp As IApplication
    Private m_ObjAppROT As IAppROT
    Private m_ObjObjectCreator As IObjectFactory
    Private m_ObjMap As IMap
    Private frmMotherform As Motherform
    Friend m_StrProject As StructProject
    Private m_al1, m_al2, m_al3 As ArrayList
    Private m_alClassifiedFields As ArrayList
    Private m_cFilename As String
#End Region
Private Function GetApplication() As Boolean
        Dim Zahl As Long
        m_ObjApp = Nothing
        Try
            Zahl = m_ObjAppROT.Count
             If TypeOf m_ObjAppROT.Item(0) Is IMxApplication Then
m_ObjApp = m_ObjAppROT.Item(0)
m_ObjDoc = m_ObjApp.Document()
m_ObjObjectCreator = m_ObjApp
Return True
            Else
                            Return False
            End If
        Catch ex As Exception
            Return False
        End Try
    End Function
End Class
