Updating config.json for Application - with Javascript
3595
9
04-25-2017 08:21 AM
ToddUlery
Is there anybody out there with tips or samples for updating WAB config.json file?
More specifically adding a widget through Javascript.
I am trying to read in the json, find where i need to add, and update the json file.
I know how to just open and manually adding the widget.
Robert Scheitlin, GISP‌ ---hoping you have some tips.
DevelopersWeb AppBuilder Custom Widgets
ToddUlery
Thanks Rebecca, I will give these a look over.
RobertScheitlin__GISP
Todd,
   I am a little confused by your goal here. Why are you wanting to update the main config.json manually. Why not use the WAB UI for that?
ToddUlery
I have some grunt tasks that run to create the widgets, and what is missing is adding it into the application. I was hoping to just add another task that reads the json, prompts the Developer for position of the widget, and updates and saves out the file.
I have been tasked to work out a dev workflow. We would like to keep the builder out of the flow as much as possible.
Todd,
   I have never attempted anything like that but the main config.json is just a basic json/text file so if you grunt task and read and write and parse the json then you should have no problem.
ToddUlery
Yeah that was the thought, but then i started getting in the weeds, and then they started to grow higher. Just not a JSON master. But i am sure i am just over thinking it.
Todd,
   You probably are. Json is pretty simple text and the widgets are just part of a arrays like
"widgetsOnScreen" : {
  "widgets": [
      "position" : {
        "left" : 105,
        "top" : 45,
        "relative" : "map"
      "id" : "_6",
      "name" : "Query",
      "version" : "2.4",
      "uri" : "widgets/Query/widget",
      "config" : "configs/Query/config_Query widget.json",
      "icon" : "widgets/Query/images/icon.png"
ToddUlery
Thanks, Robert Schmidley‌ and rastrauch‌ ---- It is a bit more complicated than I thought for the timeframe I have and would better serve to just wait on it.
On another objective; would you suggest a best practice when altering the WAB structure  (regarding CSS on Theme based Elements) to place these style updates in a separate CSS file and just @import or load this in separate. Or just tack them on to already existing CSS files where the original exists.  ???
RebeccaStrauch__GISP
Todd, if you haven't already done so, you may want to repost your new question in Web AppBuilder Custom Themes   or at least repost and then tag that group.
