I have an map with points displayed on it but in the attribute table there is text. How do I convert the points to display the text field?
558
05-03-2017 07:25 AM
KimWirth
See the attachments, the map display is points and I want to show from the attribute the table  address text
Tags (1)
IanMurray
You can turn the labels on to label the features under the layer properties, using the field of choice that you want to be the text label.
If you don't want the points symbolized themselves, you can set them to display no color so they won't appear on your map.
KimWirth
Thanks!
