Reclassify by ASCII
958
05-15-2017 08:08 PM
AnanG
I want to reclassify the landuse map as follows:
Original code
Field
New code to be given
0100
Rice paddy
Agricultural fields
Forest
Barren area – OTHERS
Built up area
5
0901
Road
5
0902
Railway
5
1000
Other inland type
Inland waters
6
1400
Coastal area
Ocean
7
1600
Golf course
Outside areas
 So I made an input ASCII remap files as follows:
# Remap Table for cell value reclassification
0100 : 1
0200 : 2
0500 : 3
0600 : 4
0700 : 5
0901 : 5
0902 : 5
1000 : 4
1100 : 6
1400 : 4
1500 : 7
1600 : 4
0000 : 4
The output that I wanted was the reclassified map with 7 unique values. I wanted codes like 0700, 0901 and 0902 to be merged together and given the value 5. However, my reclassified map looks like this.
When I open the symbology window, I do not have the option of seeing the map by different attributes.
When I do the reclassification manually, I get results like this.
What is wrong with my ASCII file?
DanPatterson_Retired
I suspect 0100 etc are not numeric ...
  • Each assignment line maps a value or range of values from the input raster to an output value. Only numeric values are accepted on an assignment line.
AnanG
Thank you! I changed the characters from strings to short integers and it worked!
