Authorizing Portal for ArcGIS silently(error)
979
05-16-2017 09:46 AM
Luiz_AmadeuCoutinho
Occasional Contributor III
I´m trying follow the instructions after install a ArcGIS Portal on linux server.
The installation is ok, I have the authorization file.. Every time a got te same error when I tryed to run.
${HOME}/arcgis/portal/tools/authorizeSoftware -h (r any options)
Error is: No such file or directory
I´m new on Linux. Someone got the same situation?
Thank you.
JonathanQuinn
Esri Notable Contributor
Strange... do you see the following folders/files?
${HOME}/arcgis/portal/framework/etc/arcenv
${HOME}/arcgis/portal/framework/runtime/qt
${HOME}/arcgis/portal/bin/softwareauthorization
GriffinMorgan1
The -h option is only to display the help for the authorizeSoftware script. That information is already in the install guide you linked to. It should not be used in the command to authorize.
