How many Web Adaptors
1112
05-17-2017 09:42 AM
JanieGoddard
Occasional Contributor III
 If Portal and Server are behind the firewall and the Web Adaptor is forward facing on the web server configured to ArcGIS Server, and we are using Built-in users and Built-in groups on ArcGIS Server and ArcGIS for Portal and I install a new 10.5 Portal, do I need to do any of the https stuff and installing the second web adaptor for Portal?
See this link: About configuring portal authentication—Portal for ArcGIS (10.5) | ArcGIS Enterprise
Configuring built-in users and groups using the portal's identity store
No steps are necessary to configure the portal when using built-in users and groups; the portal is ready for built-in users and groups immediately after installing the software. If you are using enterprise users, see the following sections and related links for more information.
JonathanQuinn
Esri Notable Contributor
You'll need two web adaptors for your deployment, (one for Server and one for Portal), and yes, you'll definitely need a valid CA signed certificate on your web server to support HTTPS.
JonathanQuinn
JanieGoddard
Hi Jonathan,
   Thanks so much for answering!
    If I used a Domain Certificate, will my external anonymous users see the browser warning about being an unsecured site?
Janie
JonathanQuinn
Yes, only a certificate that's trusted by browsers by default, (Verisign, Go Daddy, etc), will avoid certificate issues with external users, until they trust the certificate, at least, but that's not ideal.  Your internal users will be fine, as it's likely already trusted through Group Policy settings.
JanieGoddard
Thanks again Jonathan. I really appreciate your help!
Janie
