Emerging Hot Spot Analysis - Input Data for Example
568
05-18-2017 03:27 AM
by Anonymous User
Not applicable
Hello!
I am trying to run the example provided the 'Emerging Hot Spot Analysis' tool help page -
Emerging Hot Spot Analysis—Help | ArcGIS for Desktop
The input file for the example is the "Homicides.nc" NetCDF file. However, I could not locate this file in the ArcGIS Tutorials (10.5), or online on the ArcGIS website.
How can one obtain the required input files for reproducing ArcGIS tool help-page examples, such as "Homicides.nc"?
Will appreciate any guidance!
Thanks and Best regards,
Michael
JimCousins
MVP Regular Contributor
I believe that you are looking at the code sample, which is simply showing the appropriate syntax for the tool, and is not a tutorial with actual sample data. You will need to input your own data, following the syntax example provided.
Regards,
Jim
