Add Unique ID from one polygon layer to another based on spatial relationship
2127
8
05-17-2017 10:51 PM
JensJensen
Hello
I'm have two polygon layers, one have been dissolved, the other is the original data with a lot of smaller polygons in it. The polygon layers overlap each other.
Each of the dissolved polygons have an unique id, that I would like to add to all the smaller polygons, so I can see where the smaller polygons belong.
I'm thinking some kind of join or similar based on the spatial relationship (overlap), but I can't get it too work. Tried adding a concept illustration:
Input:Wanted output
Dissolved polygon IDSizeSmall polygon sizeSmall polygon ID
44791014479
14479
14479
14479
14479
14479
14479
14479
14479
JayantaPoddar
MVP Esteemed Contributor
Check the following steps
1. Convert the small polygons to points layer Feature To Point—Help | ArcGIS Desktop
2. Do a Spatial Join to migrate the data from the Dissolved Polygons to the Points.
3. Do a Spatial Join again to migrate the data from points to smaller polygons.
4. Delete the unwanted fields from the layer with smaller polygons. Delete Field—Help | ArcGIS Desktop
Think Location
FC_Basson
MVP Regular Contributor
You should be able to accomplish this with a Spatial Join: Spatial Join—Help | ArcGIS for Desktop
JensJensen
Had to do a few different version of this, but got it to work, thanks!
I've added an extra credits question to Jayantas comment, feel free to weigh in, if you know the answer
JayantaPoddar
Think Location
JensJensen
Thank you, both of the suggestion works. Much appreciated.
Another question a bit different, can you convert a raster too vector, without it grouping raster cells, so that basically each raster cell becomes a polygon?
Input rasterUnwanted output vectorWanted output in vector
No data1No dataNo data
No dataNo data    1No data
       31     8     3     8    3    1   8
       22    4        2      4    2    2   4
JayantaPoddar
JensJensen
That would work perfectly, just one little hiccup I only have an ArcGIS Standard license with Spatial Analyst.
JayantaPoddar
Alright.
While creating Fishnet, keep Geometry Type as Polygon.
Then do a Spatial Join to migrate the values of points to the polygons.
*No need to do Feature to Polygon step
Think Location
JensJensen
How did I miss that I could create polygons with the fishnet. Thank you very much, exactly what I needed!
