Question on Apply symbology layer for modelbuilder in arcpro
1416
05-19-2017 02:09 PM
PejvakZaimaran
Hi all, I have built a model in ArcGIS pro. the tools are buffer then select by location then make a feature layer. I am a little confused on how to control the symbology output for the buffer colors and transperancy once you run the model. The original layers are points, when I run the model the buffers and dissolve are bright pastel colors how do I control the symbology output with apply symbology layer?
Robert_LeClair
Esri Notable Contributor
You could create a layer file from an existing layer in Pro and apply that layer file using the "Apply Symbology from Layer" GP tool.
PejvakZaimaran
Thanks I will try that
curtvprice
MVP Esteemed Contributor
You don't need to use that tool, you can save a layer file and set the Symbology property of the tool output to your .lyr file in Model Builder‌ edit mode.
Model parameters—ArcGIS Pro | ArcGIS Desktop
