Import 3d files problem, Placement points
923
05-19-2017 08:58 PM
simontransits2
i'm using Import 3d files to bring in a collada file to multipatch layer.
If i don't use the "Placement points" option, it able to import successfully (albeit in the wrong position).
If I do use the "Placement points" option, it gives a error "ERROR 050038: No Valid Files
invalid dz
Failed to execute (Import3DFiles)."
I tried on a simple Collada file to avoid issues that may occur in more complex files. My file is "test.dae"
and my placement points layer has a column called "Name" where there is a point with the attribute value "test.dae".
Also tried to put attribute "test".
The projection is wgs84.
Hope for some input.
Thanks.
Tags (3)
