Problems using REST API to generate Tile Packages from World Topo (For Export)
1270
05-19-2017 03:18 PM
by Anonymous User
Not applicable
Using the script below it seems that I can request the generation of tile packages and then download the resulting tpk file generated by ESRI.  But when I try and open the package NOTHING shows up in ArcMap.  Can't tell what is happening - can't tell what is going wrong.  Any ideas?
import arcpy
import requests
import pandas as pd
import time
import json
def scrape_tiles(token, input_file, levels):
    tpk_grid_df = pd.read_csv(input_file, header=0)
    for index,row in tpk_grid_df.iterrows():
        extent = '{"xmin":' + str(row['XMIN']) + \
                 ',"ymin":'+str(row['YMIN']) + \
                 ',"xmax":'+str(row['XMAX']) + \
                 ',"ymax":'+str(row['YMAX']) + \
                 ',"spatialReference" : {"wkid" : 4326}}'
        req_url = 'http://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Topo_Map/MapServer/exportTiles?' \
                  'tilePackage=true' \
                  '&exportExtent=' + extent + \
                  '&optimizeTilesForSize=true' \
                  '&compressionQuality=90' \
                  '&exportBy=levelId' \
                  '&levels=' + str(levels) + \
                  '&f=json' \
                  '&token=' + str(token['token'])
        resp = requests.get(req_url)
        resp_cont_dic = json.loads(resp.content)
        jobID = resp_cont_dic['jobId']
        jobStatus = resp_cont_dic['jobStatus']
        print(jobStatus)
        while jobStatus == 'esriJobSubmitted' or  jobStatus == 'esriJobExecuting':
            time.sleep(15)
            req_status_url = 'http://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Topo_Map/MapServer/jobs/' \
                             + str(jobID)\
                             + '?f=json' \
            status_resp = requests.get(req_status_url)
            status_resp_cont = json.loads(status_resp.content)
            jobStatus = status_resp_cont['jobStatus']
        if jobStatus == 'esriJobFailed':
            print('esriJobFailed')
            break
        # GRABBING THE RESULTS
        res_url = 'http://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Topo_Map/MapServer/jobs/' \
                  + str(jobID) \
                  + '/results/out_service_url?f=json' \
        result_resp = requests.get(res_url)
        result_resp_cont_dic = json.loads(result_resp.content)
        result_url = result_resp_cont_dic['value'] + '/Layers.tpk'
        file_name = 'NH_TP_' + str(levels) + '_' str(row['ID']) + '.tpk'
        r = requests.get(result_url)
        with open(file_name, 'wb') as f:
            for chunk in r.iter_content(chunk_size=1024):
                if chunk:  # filter out keep-alive new chunks
                    f.write(chunk)
                    f.flush() #commented by recommendation from J.F.Sebastian
        f.close()
if __name__ == "__main__":
    arcpy.SignInToPortal_server("USERNAME", "PASSWORD", "")
    token = arcpy.GetSigninToken()
    input_file = "TPK_Grid_100.csv"
    num_levels = 17
    #print(token)
    scrape_tiles(token, input_file, num_levels)
by Anonymous User
Not applicable
Fixed it using the code below:
import arcpy
import requests
import pandas as pd
import time
import json
import os.path
global skip_count
def gen_token():
    return str(token['token'])
def check_status(jobID, token):
                     + jobID \
                     + '?f=json' \
                       '&token=' + token
    return str(status_resp_cont['jobStatus'])
def scrape_tiles(input_file, levels):
    token = gen_token()
    row_count = len(tpk_grid_df)
    skip_count = 0
        try:
            file_name = 'NH_TP_' + str(levels) + '_' + str(int(row['Grid_ID'])) + '.tpk'
            if os.path.isfile(file_name):
                skip_count += 1
                continue
            extent = str(row['XMIN']) + ',' + str(row['YMIN']) + ',' + str(row['XMAX']) + ',' + str(row['YMAX'])
            #extent = '{"xmin":' + str(row['XMIN']) + \
            #         ',"ymin":'+str(row['YMIN']) + \
            #         ',"xmax":'+str(row['XMAX']) + \
            #         ',"ymax":'+str(row['YMAX']) + \
            #         ',"spatialReference" : {"wkid" : 102100}}'
                      '&optimizeTilesForSize=false' \
                      '&compressionQuality=false' \
                      '&levels=1-' + str(levels) + \
                      '&f=json' \
                      '&token=' + token
            jobID = str(resp_cont_dic['jobId'])
            jobStatus = str(resp_cont_dic['jobStatus'])
            print(jobStatus)
                print('Job Processing: ' + str(int(row['Grid_ID'])))
                time.sleep(5)
                jobStatus = check_status(jobID, token)
                print('esriJobFailed: ' + str(int(row['Grid_ID'])))
                break
                      + str(jobID) \
                        '&token=' + token
            print ("Downloading job: " + str(int(row['Grid_ID'])))
                        f.write(chunk)
            f.close()
        except:
            print('Error with job: ' + str(int(row['Grid_ID'])))
            continue
    return skip_count
    input_file = "TPK_Grid.csv"
    num_levels = 17
    tile_count = 71
    skip_count = 0
    while(skip_count < tile_count):
        print('skip_count: ' +str(skip_count))
        skip_count = scrape_tiles(input_file, num_levels)
by Anonymous User
Not applicable
import arcpy
import requests
import pandas as pd
import time
import json
import os.path
global skip_count
def gen_token():
                     + jobID \
                     + '?f=json' \
                       '&token=' + token
    token = gen_token()
    skip_count = 0
        try:
                skip_count += 1
                continue
                      '&f=json' \
                      '&token=' + token
            print(jobStatus)
                time.sleep(5)
                break
                      + str(jobID) \
                        '&token=' + token
                        f.write(chunk)
            f.close()
        except:
            continue
    return skip_count
    num_levels = 17
    tile_count = 71
    skip_count = 0
