Calculator field error
862
05-20-2017 09:40 PM
lesnagy
I am trying to calculate percent deforestation in tutorial but get a processing error.  I believe it is because the file name has already been used, though I can't read the error scripts because I have a high resolution screen (4K).  I have tried over-writing the outputs of geoprocessing - to no avail.  My biggest problem lies in the fact that arcMap software doesn't work well with 4K resolution, therefore, text within certain windows is unreadable (scrunched together).  I believe ESRI is working on resolving this software issue.  Does anyone know?
JayantaPoddar
MVP Esteemed Contributor
Check the workaround by Dan Patterson‌ for display issue in Hi-Res. Monitors. It would require a Windows 10 update to ver. 1703 or later.
https://community.esri.com/thread/194833-toolbars-not-showing-completely#comment-686422
Think Location
AbdullahAnter
Occasional Contributor III
Is this question relate to your question in the following link?
https://community.esri.com/thread/195372-geoprocessing-error-message-file-already-exists
