Geo data is not syncing to map?
809
05-22-2017 05:18 AM
KaraHarmet1
I am working with Survey123 and one question involves geopoints. The data is not showing up on the map. The layer is on the map but the points are not showing up. The attribute table for the layer is empty. It also says that there are no records, yet others have definitely sent submissions in. I have tested another survey with geopoint questions and those sync to its respective map with no issue. I have attached 2 screenshots, hopefully that helps illustrate what I am talking about. Any ideas on what the issue could be?
Thank you,
Kara
by Anonymous User
Not applicable
Hi Kara,
Given the attribute table of the feature service is empty, this would suggest that no features have been successfully uploaded from the devices and why you do not see any points on the map. Do you have access to the devices that were used with the Survey123 app installed? Can you confirm the surveys still exist in the Sent folder and that there is no error message against the survey?
Regards,
Phil.
