REST API for adding a record
2327
05-22-2017 02:04 PM
NaciDilekli
I would like to add records to a table using REST API. I followed Robert Scheitlin, GISP‌'s example to retrieve a table here, and modified the URL with the following one:
"http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/FeatureServer/1/addFeatures?features=[{'attributes' : {'agree_with_incident' : '2', 'notes' : 'my notes..'}}]&f=json";‍
based on Domenico Ciavarella's answer in this post. However, I am getting this error in the console when I try to execute the request: "dojo.io.script error Error: Unable to complete operation."
I am very new to the REST API, and I don't see many examples. Here is my entire code
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Add a Record</title>
  <style>
    td {
      padding: 4px;
    #loading {
      visibility: hidden;
  </style>
  <script src="http://js.arcgis.com/4.2/"></script>
  <script>
    require([
      "esri/request",
      "esri/config",
      "dojo/json",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
    ], function(esriRequest, esriConfig, JSON, dom, on) {
      esriConfig.request.proxyUrl = "http://gislap183/js/proxy/proxy.ashx";
      function doRequest(){
        var url = "http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/FeatureServer/1...[{'attributes' : {'agree_with_incident' : '2', 'notes' : 'my notes..'}}]&f=json";
        esriRequest(url, {
          responseType: "json",
          callbackParamName: "callback"
        }).then(function(response){
          showResults(response);
      var resultsTable = dom.byId("tbl");
      // Executes when the promise from find.execute() resolves
      function showResults(response) {
        var results = response.data;
        // Clear the cells and rows of the table to make room for new results
        resultsTable.innerHTML =  JSON.stringify(results);
      // Executes each time the promise from find.execute() is rejected.
      function rejectedPromise(err) {
        console.error("Promise didn't resolve: ", err.message);
      // Run doRequest() when button is clicked
      on(dom.byId("execBtn"), "click", doRequest);
  </script>
</head>
<body>
  <input type="button" value="Execute" id="execBtn" />
  <br>
  <br>
  <table id="tbl"></table>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
How can I fix this? Thanks.
RobertScheitlin__GISP
Naci,
   Here is the code working. Make sure you change the proxy url to your proxy url or it will not work:
<!DOCTYPE html>
<html>
<head>
  <style>
    td {
      padding: 4px;
    #loading {
      visibility: hidden;
  </style>
  <script src="http://js.arcgis.com/4.3/"></script>
  <script>
    require([
      "esri/request",
      "esri/config",
      "esri/core/urlUtils",
      "dojo/json",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
    ], function(esriRequest, esriConfig, urlUtils, JSON, dom, on) {
        var url = urlUtils.urlToObject("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/FeatureServer/1...[{'attributes':{'agree_with_incident':2,'notes':'problemo grande1'}}]&f=json");
        esriRequest(url.path, {
          query: url.query,
          useProxy: true,
          callbackParamName: "callback",
          method: "post"
        }).otherwise(rejectedPromise);
  </script>
</head>
<body>
  <br>
  <br>
</body>
</html>
Naci,
<!DOCTYPE html>
<html>
<head>
  <style>
    td {
      padding: 4px;
    #loading {
      visibility: hidden;
  </style>
  <script>
    require([
      "esri/request",
      "esri/config",
      "dojo/json",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
          query: url.query,
          useProxy: true,
          method: "post"
  </script>
</head>
<body>
  <br>
  <br>
</body>
</html>
NaciDilekli
Thank you very much, Robert. However, when I try to execute the query, I get the following errors in the console:
And when I check the records I see that my records are not added. I can see that you were able to add records yesterday. So I wonder why mine is not working.
Now I should tell that I used whatever proxy address you mentioned. I don't know anything about proxies, should I have made my own proxy?
Naci,
Yes , I mentioned that you would have to change the proxy url to your own proxy. I guess you have to start learning about proxies then.
GitHub - Esri/resource-proxy: Proxy files for DotNet, Java and PHP.
Setting up a Proxy | Support Services Blog
NaciDilekli
Thank you very much!
