Application on Production Server requesting user and password to buffer
1273
05-22-2017 08:46 AM
GilbertoMatos
Occasional Contributor II
Hello!
When trying to execute buffer in our application on the production server, user and password is requested to the address "http://gis.fepam.rs.gov.br/arcgis (Utilities / Geometry)".
If I use the geometry service of the esri "http://gis.fepam.rs.gov.br/arcgis/rest/services/Utilities/Geometry/GeometryServer", it works correctly.
Our server has no proxy, so the file "config.json" includes "proxy: false".
I included the application inside the "c: \ inetpub \ wwwroot \ SigFepam" folder of our server, but did not create virtual directory.
What could be happening? Should I do any specific configuration?
When the user and password are requested, I try to inform a valid users and passwords of ArcGis Server Manager, but I do not succeed.
Any help will be helpful.
Thank you!
Gilberto.
RobertScheitlin__GISP
Gilberto,
  So on the production server go to ArcGIS Server Manager and see if the lock is locked or open like in the attached image:
Gilberto,
   It seems that you have locked (secured) your GeometryService. If it was not secured then you would be able to go straight to it with out logging in. So the simple answer is have your ArcGIS Admin un-secure the Geometry Service.
GilbertoMatos
Hello robert
I really do not know what's going on. I tried to check in ArcGIS Manager some option for this, but I did not find anything.On our development server, there is no such password request, but in production yes. The bottom line is that even the analyst who manages the tool does not know how to proceed. Do you know where I should check if the geometry service is blocked or is it a secure service?
Thank you for your help.
Gilberto
Gilberto,
GilbertoMatos
Hello Robert
Perfect, that's right. The geometry service was the only one that was blocked.
Thanks again.
Hug,
Gilberto.
