How to create AddEdit app from sample?
1233
05-24-2017 04:06 AM
MikalaRandich
I am trying to create an app from the Add/Edit sample provided in App Studio (Desktop 1.4.18) and am having trouble changing it to use one of our feature service layers instead of the provided default. I'm not very good with coding, but have changed these lines in Qt to try to get the app to load a different feature service layer from ArcGIS Online, but none of the points hosted in the feature service appear in the app and it is no longer "clickable" to add a new point. Any advice on what I'm doing wrong would be greatly appreciated!
Thank you,
Mikala
Changed line 36 from
property string featureServiceURL : appWindow.info.propertyValue("featureServiceURL","");
to
property string featureServiceURL : appWindow.info.propertyValue("https://services1.arcgis.com/5Gtv38l8677OspKm/arcgis/rest/services/survey_database_join/FeatureServe...","");
Changed line 70 from
url: appWindow.info.propertyValue("basemapServiceUrl", "http://server.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer")
to
url: appWindow.info.propertyValue("basemapServiceUrl", "https://scgis.maps.arcgis.com/home/webmap/viewer.html?webmap=c0e67a328e69428ba26209544a613255")
Changed line 76 from
url: "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0"
to
url: "https://services1.arcgis.com/5Gtv38l8677OspKm/arcgis/rest/services/database_survey_join/FeatureServe..."
nakulmanocha
Please revert the changes back to original code.
You cannot replace basemapserviceurl with a webmap. So if you are interested in a specific basemap get the url and replace it with the one on line 70. But remember it is optional.
Only thing you really need to change is the featureservice url on line 76. Also url of the layer must end with some index such as "0" which defines the Layer index. So the right url would be
And it looks like your layer is secured which requires OAuth 2.0 authentication. For that please refer this
Use OAuth 2.0 authentication—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
But for testing purpose just make your service publically available for brief moment and test the layer as mentioned above in the sample and you should be able to add and view features.
I hope this helps.
Nakul
nakulmanocha
I hope this helps.
Nakul
MikalaRandich
Hi Nakul,
Thank you so much for your help! Your instructions worked well, I made the online feature service shared with 'everyone' and now the app allows me to view, click, and edit features from the layer I wanted. However, I still can't click and add a new point, and ideally I'd like to change the basemap to World Imagery, which I attempted but didn't work. Any further suggestions? Let me know if you'd like to look at the entire code or different portions of it.
Thanks again,
Mikala
//BASEMAP
        ArcGISTiledMapServiceLayer {
            url: appWindow.info.propertyValue("basemapServiceUrl", "http://server.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer")
 //ADD POINT FUNCTION
    function addPoint(pointX, pointY, pointSR) {
        if (addButtonClicked == "add item"){
            //console.log(pointX+500);
            var featureJson = {
                geometry: {
                    x: pointX,
                    y: pointY,
                    spatialReference: pointSR
                attributes: {
                    eventtype : "eventtype",
                    eventdate : "district",
                    eventtype: 17
        if (featureServiceTable.featureTableStatus === Enums.FeatureTableStatusInitialized) {
            var newFeature = featureServiceTable.addFeature(featureJson);
            dispTable(newFeature);
nakulmanocha
To change the basemap. Please make the edit in the appinfo.json properties like below. That is where it picks the basemapServiceurl value
"properties": {
        "basemapServiceUrl": "http://server.arcgisonline.com/arcgis/rest/services/World_Imagery/MapServer",
        "titleBackgroundColor": "#00b2ff",
        "titleTextColor": "#fefdfd"
Also make sure your feature service layer has the editing permissions to add new features from the  Feature Layer (hosted settings.
Finally make sure the attributes match to attributes listed in the Add Point function code. I am sure your feature layer doesn't have the following attributes
attributes: {
                    eventtype: 17
MikalaRandich
