Set data source on Local Government Information Model
529
05-24-2017 05:40 AM
JefferyLeuenberger
I am trying to use the Local Government Solutions for Base Maps. I use the 'Set map data source' tool to point to our SDE database connection on ArcServer. When I open the map file, the data source for each item points to the exact feature in our organizations database. However, nothing is displayed. When I zoom to features, nothing. I make sure to have the scale at the correct level. Just to test, I place the feature from the database into the map and that feature appears. When I compare the data source for the feature I added and the feature in the map document, it's exactly the same. However, when I open the attribute table it's blank as well. When I open the attribute table for the feature I added (exact same data source in the map) the data is there.
What am I doing wrong?
AllisonMuise1
Occasional Contributor III
jleuenbe
It sounds like you've done everything right, so I suggest contacting Esri support, or your local distributor to figure out what is going on. Both the basemaps solution and the data sources tool are fully supported.
