Basin Model File error
1496
05-27-2017 10:48 AM
RashidMahmood1
 I have been working with Window 7 (64 bit), HEC-GeoHMS 10.2 version, ArcGIS 10.2.2 and was trying to update the Basin Model file Error.
Before, it was running smoothly and I created the Basin Model file accurately. Lately, I made some more calculations for model parameters and wanted to update the Basin Model File, but when I tried to update the file I received the following error and, the Model File which I created last time was also disappeared from the main directory
Error HRESULT E_FAIL has been returned from a call to a COM component
Please reply as soon as possible cause I m stuck now on one point
BenPoole
I'm getting the same error now trying to export my Basin Model file. Did you ever figure this out?
SheilaFrias
Same with me..What I'm doing at the moment is starting over again but it takes alot of time.
jasonphillips3
Is there a fix for this?! I'm having the same issue! I even started over to make sure all my files and paths were not broke. I ran through the entire geoHMS tool bar with out any errors, but get the same error on the last step to import into HMS.
