Activate the ArcGIS pro Map tool by the code
1699
7
05-28-2017 02:02 AM
AmmarAssem1
Hi All,
I am working now with ArcGIS pro map tool, to help the user to draw sketches in the map it is fine for me,
But my problem is, I created a windows form for business and I need to activate this map tool by the code, so the user will add some data and If he need to draw something he clicks on a button and I will activate this tool. There is any way to do this or the only way to draw the sketches by using the Map Tool.
Ammar Assem.
DanPatterson_Retired
If you are transitioning from ArcMap... see the FAQ sections
If you are using python toolboxes, .... see python toolboxes in PRO
AmmarAssem1
Thanks Dan,
I do this by ArcGIS add-in SDK, I need to do this in ArcGIS pro, not  by Arcpy.
Haven't use it, but there are links on GitHub
AmmarAssem1
Thanks Dan, I checked it, the existing way by Map  Tool, and I need it by the code.
I guess you will have to specify what type of code.  .Net and python ruled out so far
AmmarAssem1
.Net
Like ArcGIS PRO SDK for .NET ?  You ruled that one out or do you want an alternate link? or a search by keyword
