Model builder date variable
1929
05-26-2017 10:23 AM
JoseSanchez
Occasional Contributor III
Hello everyone,
How to add a date variable in an expression?
I am working with a FGDB in  ArcGIS  10.2
I have two variables in Model Builder script:
  - DateFrom populated with 5/1/2017 1:03:07 PM
  - DateTo populated  with 5/31/2017 1:03:23 PM
an the expression I tried with MakeFeature:
CRTDATE >= %DateFrom%  and \nCRTDATE  <= %DateTo%  => fails
CRTDATE >= #%DateFrom%#  and \nCRTDATE  <= #%DateTo%#    => fails
ERROR 000230: Failed selecting with CRTDATE >= #5/1/2017 1:03:07 PM# and \nCRTDATE <= #5/31/2017 1:03:23 PM#
An invalid SQL statement was used.
Any suggestion?
curtvprice
MVP Esteemed Contributor
I would avoid the embedded newline in the expression. The syntax is data source dependent, for file geodatabase try:
CRTDATE >= date '%DateFrom%' AND CRTDATE  <= date '%DateTo%‍‍‍'
I got the syntax from the help. I have this one bookmarked!
SQL reference for query expressions used in ArcGIS—Help | ArcGIS Desktop  (dates and times)
curtvprice
JoseSanchez
Your format works thank you!
CRTDATE >=  date  '%DateFrom%'  and CRTDATE  <= date  '%DateTo%'
