How to Georeference multipatch files?
3055
05-31-2017 03:46 AM
XevGoh
(updated question) Hello! I have a 3d problem that I hope the community can guide me on!
Data Sources:
  • Files in 3DS and DAE format
Steps taken so far:
  • Used Import 3D Files Tool on ArcScene to convert the 3DS files for visualisation in ArcScene
Problem: The multipatch output generated using Multipath footprint Tool came with my preferred coordinates system, but it does not appears with the rest of my georeferenced items.
Question: is there a way to georeference the multipatch files on ArcScene/ other ArcGIS softwares?
Thank you very much!
XevGoh
Hi everybody, I figured the answer to my question, thought i'll share my workflow here too!
Solution:
  • Multipatch files can be edited in ArcMap
  • Use Spatial Adjustment Tool in ArcMap to georeference the 3D output to a georeferenced basemap
    • When adjusting data, choose all features in this layer
    • Add links
    • Adjust
  • The adjusted output should be georeferenced after this and will appear in the correct place when viewed in ArcScene!
Have a good day
TimothyHales
Esri Notable Contributor
You will need to edit a multipatch feature class and place the model during that edit session. You could also symbolize a point feature class with the model and convert the symbolized points to a multipatch feature class. You may have to export it as a recognizable format such as DAE/3DS/FLT if your multipatch is not recognizable.
How to import an existing 3D model into a multipatch feature class—Help | ArcGIS Desktop
I have also moved this discussion to https://community.esri.com/community/gis/3d?sr=search&searchId=bad29260-f0e2-4122-b047-27084b011159&...‌ as GeoNet Help is for information and questions related the community.
XevGoh
Thanks Timothy for placing my discussion in the correct space!
I have visited the webpage on "how to import an existing 3D model into a multipatch feature class" before, but unfortunately still did not manage to advance further. I have updated my question to reflect my methodologies thus far!
XevGoh
Solution:
    • Add links
    • Adjust
Have a good day
ABDURRAHAMANMIRZA
Tried many times, but spatial adjust leads 3d model into 2d
