want to add my widgets in a folder widget
837
06-04-2017 05:34 AM
AbdelwajidSafiri
hi i'm using arcgis viewer for flex (3.7) and i want to add my widgets in a folder widget like as in the image attached please
JayantaPoddar
MVP Esteemed Contributor
Hi Abdel,
Check the grouping of widgets (including sample) in  ArcGIS Viewer for Flex - Widget Container . You will need to make necessary changes in the config file.
Widgets can also be grouped within the widget container. This enables widgets to be collected together for organizational purposes in the Viewer UI. Widgets can be grouped in the widget container using the <widgetgroup> tag, which is a child tag to <widgetcontainer> and a parent tag to <widget>. <widgetgroup> has the following attributes:
  • label—Name of the group.
  • icon—Icon used for the widget group in the widget tray. The default folder icon is i_folder.png.
    Default folder icon
Think Location
AbdelwajidSafiri
Hello and thank you for your review, please I am a beginner and I am wondering what I can give you access to my computer with teamviewer to show me, here is my email: safiri.abdelwajid.1@gmail.com
