Geometry reference system, Big Data Store logging
566
06-07-2017 03:07 AM
ChristophKisfeld
I have a 10.5 Geoevent setup with an Elasticsearch Big Data Store on a separate host.
Question 1: I'm pushing events over a TCP Socket in a comma separated list. After some trial and error I found that the geometry format looks something like this:
...,othervalue,"51.0,7.2",othervalue,...
Is it possible to specify a CRS here, maybe en EPSG code, Z value...? I couldn't find detailed documentation on how data types have to be formatted.
Question 2: One of my Elasticsearch BDS writers failed to output data, the cause of this was that I put an "Update Features" instead of "Add Features" output.
While looking for the cause of this, I noticed that the logs on my server (C:\...\logs\example.com\elasticlog) were always empty (0 byte). The ArcGIS Server/GeoEvent Manager's logs didn't show anything useful either on "DEBUG".
I tried to change the log level in \elasticsearch_2.3.2\config\logging.yml from "ERROR" to "DEBUG", but that didn't change anything -- How can I log failed INSERT and UPDATE attempts in the Elasticsearch BDS?
ChristophKisfeld
I solved problem number 1.
Input connector settings:
  • Construct Geometry From Fields:    Yes
  • X Geometry Field: x
  • Y Geometry Field: y
  • Z Geometry Field: (empty)
  • WKID Field or Default WKID: wkid
GeoEvent Definition corresponding fields:
  • x - Float
  • y - Float
  • wkid - Integer
  • geometry - Geometry (last field in the definition)
Then submit your data like this (in case of the TCP input reader), the "geometry" is simply left out (already supplied from x,y data):
          x         y         wkid
otherdata,1234.1234,5678.5678,25832‍‍
