Drawing / Measuring widget with line degrees
936
06-09-2017 11:07 AM
SvivaManager
Occasional Contributor II
Anyone knows on an existing widget or simple way to add degrees/angle for the measuring/drawing tools on a WAB application? I found a different kind of degree unit in the eDraw or eMeasure widget. I'm referring to a simple 0-360 degrees unit.
Regards,
Shay.
CCWeedcontrol
Occasional Contributor III
The Measure Widget has options to show Measurement and bearings.
https://community.esri.com/docs/DOC-3209
SvivaManager
Thanks but the degrees shown in this tool are different then what my users requires. I just need 0-360 degrees unit. Also, it doesn't show anything when drawing a simple straight line.. Maybe I'm using it wrong I don't know.. It doesn't looks like it's what I'm searching for  see attached picture -
