ArcGIS Javascript API - Label renderers from Map Service for a FeatureLayer
1218
06-13-2017 05:42 AM
MaximeDemers
Occasional Contributor III
I wonder if it is possible to use the labels renderers defined in a .mxd published as a Map Service (Feature Access enabled) for a FeatureLayer with the javascript API v4.3 just like it works with the geometry renderer?
I define a featureLayer like this:
var organismesLayer = new FeatureLayer({
  url: "https://infogeo.education.gouv.qc.ca/arcgis/rest/services/SandBox_Maxime/GDUNO/MapServer/1",
  labelsVisible: true
In the map, I see the layer style is the same than in the .mxd, but the labels are not visible. Do I have to define the LabelClass manually in the javascript code?
Is there a way to get the label renderers from the Map Service?
RobertScheitlin__GISP
Maxime.
   Have you seen this limitation?
Known Limitations
There is no support for labeling in 2D. Labeling is only supported in 3D
MaximeDemers
Hi Robert,
You example is using a MapImageLayer, but I am asking about a FeatureLayer. And I see in the example that they creating the LabelClass used as label renderers instead of getting it from the service.
Maxime.
Known Limitations
MaximeDemers
Oh! That's right. I think I'll go back to v.3.20 then
Thank you very much !
