Setting legendLayer subLayerIds for PrintTask with Multiple Map Services
920
06-13-2017 02:14 PM
LoriEmerson_McCormack
I have successfully gotten the PrintTask to work with multiple map services with a legend.  By hard-coding the list of legendLayer.subLayerIds, it works.
However, I want to look up the visible layers in the map and return an array of layer indexes and assign that array to the legendLayer.subLayerIds for each map service.  I have tried various things such as (1.) using a loop and pushing each array value into legendLayer.subLayerIds, (2.) using brackets (e.g., legendLayer.subLayerIds = [returnedArray], (3.) creating a string instead of an array with commas in between each layer index (e.g., "[38,44]").  Option (3.) actually works, but even if I pass a blank string (e.g., "[ ]"), all of the visible layers for that map service are included in the print legend.
Here is the code that works with the hard-coded values for the legendLayer.subLayerIds:
<!DOCTYPE html>
<html>
<head>
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="apple-mobile-web-app-status-bar-style" content="black-translucent">
<meta name="mobile-web-app-capable" content="yes">
<title>ArcGIS dynamic and tile layers using Popup and InfoTemplates</title>
<script type="text/javascript" src="../jquery/jquery-1.11.3.min.js"></script>
<!--<script type="text/javascript" src="../jquery-ui-1.10.4/jquery-ui-1.10.4/ui/jquery-ui.js"></script>-->
<script type="text/javascript" src="../jquery/jquery-ui-1.10.4/ui/jquery-ui.js"></script>
<link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
<style>
html, body, #ui-esri-map {
width: 100%;
height: 100%;
margin: 0;
padding: 0;
.esriPopup .titlePane {
text-shadow: none;
.esriPopup .titleButton.next {
right: 40px;
.esriPopup .titleButton.prev {
right: 53px;
.demographicInfoContent {
padding-top: 10px;
.demographicInnerSpacing {
display: inline-block;
width: 8px;
.demographicNumericPadding {
width: 90px;
text-align: right;
#info{
top: 0px;
right: 0px;
position: absolute;
z-index: 99;
opacity: 0.9;
background-color: whitesmoke;
border-bottom-left-radius: 8px;
padding: 0px 0px 0px 10px;
#infoPrint{
bottom: 5px;
left: 5px;
position: absolute;
z-index: 99;
opacity: 0.9;
background-color: lightpink;
border-top-right-radius: 8px;
padding: 10px 10px 20px 10px;
width: 20%;
</style>
<script src="https://js.arcgis.com/3.20/"></script>
<script>
$(document).ready(function () {
var map;
// layer indexes in the map services
var indexPoint_StormwaterOuterZoom = 34;
var indexPoint_StormwaterMiddleZoom = 35;
var indexPoint_StormwaterCloseUpZoom = 36;
var indexPoint_ControlPts = 1;
var indexPoint_FiberPts = 9;
var indexPoint_ReferencePts = 11;
var indexPoint_SchoolBusStopsOSPI = 19;
var indexPoint_AvistaPoleStructure = 28;
var indexPoint_Shop = 5;
var indexLine_PriorityArray = 13;
var indexLine_RoadSegments = 38;
var indexLine_Railroad = 41;
var indexLine_Waterline = 44;
var indexPoly_NoTrucks = 32;
var indexPoly_CountyBdry = 13;
var indexPoly_Parcels = 53;
var indexPoly_MuniBdry = 83;
var indexPoly_Waterbody = 27;
require([
"dojo/dom-construct",
"esri/Color",
"esri/dijit/Popup",
"esri/InfoTemplate",
"esri/dijit/Legend",
"esri/layers/ArcGISDynamicMapServiceLayer",
"esri/map",
"esri/tasks/PrintTask",
"esri/tasks/PrintTemplate",
"esri/tasks/PrintParameters",
"esri/tasks/LegendLayer",
"esri/config",
"dojo/parser",
"dojo/domReady!"
], function (
domConstruct, Color, Popup, InfoTemplate, Legend,
ArcGISDynamicMapServiceLayer, Map,
PrintTask, PrintTemplate, PrintParameters, LegendLayer,
esriConfig,
parser
parser.parse();
//This sample may require a proxy page to handle communications with the ArcGIS Server services. You will need to
//replace the url below with the location of a proxy on your machine. See the 'Using the proxy page' help topic
//for details on setting up a proxy page.
esriConfig.defaults.io.proxyUrl = "/proxy/";
esriConfig.defaults.io.alwaysUseProxy = false;
var initialExtent = new esri.geometry.Extent(
-117.83, 47.23,
-117.03, 48.055,
new esri.SpatialReference({ wkid: 4326 })
map = new Map("ui-esri-map", {
basemap: "topo",
extent: initialExtent,
sliderStyle: "small"
var polygonsLayer = new ArcGISDynamicMapServiceLayer("http://igis.spokanecounty.org/arcgis/rest/services/PublicWorks/PublicWorksQueriesPolygons/MapServer", {
"id": "polygonsLayer",
"opacity": 0.75
polygonsLayer.setVisibleLayers([53]);
map.addLayer(polygonsLayer);
var linesLayer = new ArcGISDynamicMapServiceLayer("http://igis.spokanecounty.org/arcgis/rest/services/PublicWorks/PublicWorksQueriesLines/MapServer", {
"id": "linesLayer",
"opacity": 0.75
linesLayer.setVisibleLayers([38]);
map.addLayer(linesLayer);
var pointsLayerURL = "http://igis.spokanecounty.org/arcgis/rest/services/PublicWorks/PublicWorksQueriesPoints/MapServer";
var pointsLayerOptions = {
"id": "pointsLayer",
"opacity": 0.8,
"showAttribution": false
var pointsLayer = new ArcGISDynamicMapServiceLayer(pointsLayerURL, pointsLayerOptions);
pointsLayer.setVisibleLayers([4, 5]);
map.addLayer(pointsLayer);
map.on("load", function (evt) {
var legend = new Legend({
map: map,
layerInfos: [{
layer: linesLayer,
title: "Lines Layer"
layer: pointsLayer,
hideLayers: [4],
title: "Points Layer"
}, "legendDiv");
legend.startup();
firstPrint();
var customHeader = 'Spokane County Public Works';
var customScale;
var printToScale;
// btnPrint click function
$('#btnPrint').on('click', function () {
$(document.body).css({ 'cursor': 'wait' });
map.setMapCursor("wait");
if ($('#txtCustomHeader').val().length < 1) {
else {
customHeader = $('#txtCustomHeader').val();
if ($('#chkPrintScale').is(':checked')) {
printToScale = true;
else {
printToScale = false;
if ($('#txtCustomScale').val().length < 1) {
customScale = map.getScale();
else {
customScale = $('#txtCustomScale').val();
// points legend
var legendLayerPrintPoints = new LegendLayer();
legendLayerPrintPoints.layerId = "pointsLayer";
legendLayerPrintPoints.subLayerIds = [indexPoint_Shop];
// lines legend
var legendLayerPrintLines = new LegendLayer();
legendLayerPrintLines.layerId = "linesLayer";
legendLayerPrintLines.subLayerIds = [indexLine_RoadSegments];
// polygons legend
var legendLayerPrintPolygons = new LegendLayer();
legendLayerPrintPolygons.layerId = "polygonsLayer";
legendLayerPrintPolygons.subLayerIds = [indexPoly_CountyBdry, indexPoly_Parcels, indexPoly_MuniBdry];
var visiblePrintSublayerPoints = [], visiblePrintSublayerLines = [], visiblePrintSublayerPolygons = [];
// No need to exclude any Point layers from the legend
if (legendLayerPrintPoints.subLayerIds.length > 0) {
visiblePrintSublayerPoints = legendLayerPrintPoints.subLayerIds;
// Exclude some Line layers from the legend that are self-explanatory
if (legendLayerPrintLines.subLayerIds.length > 0) {
for (var i = 0; i < legendLayerPrintLines.subLayerIds.length; i++) {
if (legendLayerPrintLines.subLayerIds == indexLine_RoadSegments || legendLayerPrintLines.subLayerIds == indexLine_Waterline || legendLayerPrintLines.subLayerIds == indexLine_Railroad) {
else {
visiblePrintSublayerLines.push(legendLayerPrintLines.subLayerIds);
// Exclude some Polygon layers from the legend that are self-explanatory
if (legendLayerPrintPolygons.subLayerIds.length > 0) {
for (var j = 0; j < legendLayerPrintPolygons.subLayerIds.length; j++) {
if (legendLayerPrintPolygons.subLayerIds == indexPoly_CountyBdry || legendLayerPrintPolygons.subLayerIds == indexPoly_MuniBdry || legendLayerPrintPolygons.subLayerIds == indexPoly_Waterbody) {
else {
visiblePrintSublayerPolygons.push(legendLayerPrintPolygons.subLayerIds);
if ($('#chkPrintLegend').is(':checked')) {
legendLayerPrintPoints.subLayerIds = visiblePrintSublayerPoints;
legendLayerPrintLines.subLayerIds = visiblePrintSublayerLines;
legendLayerPrintPolygons.subLayerIds = visiblePrintSublayerPolygons;
else {
legendLayerPrintPoints.subLayerIds = [];
legendLayerPrintLines.subLayerIds = [];
legendLayerPrintPolygons.subLayerIds = [];
var printUrl = "http://gisfarm.spokanecounty.org/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%...";
var printTask = new PrintTask(printUrl);
var template = new PrintTemplate();
template.format = "PDF";
template.layout = $('#dlPrintTemplates').val();
template.layoutOptions = {
legendLayers: [legendLayerPrintPoints, legendLayerPrintLines, legendLayerPrintPolygons],
titleText: customHeader,
scalebarUnit: "Feet"
template.preserveScale = printToScale;
template.outScale = customScale;
var params = new PrintParameters();
params.map = map;
params.template = template;
printTask.execute(params, getPrinted, getPrintError);
function getPrinted(evt) {
window.open(evt.url);
$(document.body).css({ 'cursor': 'pointer' });
map.setMapCursor("pointer");
function getPrintError(evt) {
alert(evt);
}); // end btn-Print click function
// first print ; need to execute this on map load to avoid a print error
function firstPrint() {
var legendLayer = new esri.tasks.LegendLayer();
legendLayer.layerId = "pointsLayer";
legendLayer.subLayerIds = [4];
//alert(e.target.id);
printUrl = "http://gisfarm.spokanecounty.org/arcgis/rest/services/PublicWorks/CustomPrintLayouts/GPServer/Export...";
//var nparcel = ;
template.layout = "ParcelLayoutLandscape";
legendLayers: []
template.preserveScale = true;
params.map = map;
//window.open(evt.url);
alert(evt);
// do something on button click
}); // end require
}); // end document ready
</script>
</head>
<body>
<div id="ui-esri-map"></div>
<div id="info">
<div id="legendDiv"></div>
</div>
<div id="infoPrint">
<div id="PrintDiv">
<div>Basic Print: To print the map with added graphics select Template from Print Template list. To include custom header or print at specficied scale select Template then enter those values.</div>
<!--<input type="submit" value="Print" id="btnPrint" data-mini="true" data-corners="false" />-->
<!--<div id="btnBasicPrint"></div>-->
<br>
<div>
<label for="txtPrintTemplates">Print Templates</label>
<select id="dlPrintTemplates" style="width:100%;">
<option value="Letter ANSI A Landscape">Letter Landscape(PDF)</option>
<option value="Letter ANSI A Portrait">Letter Portrait(PDF)</option>
<option value="MAP_ONLY">Map Only Landscape(PNG)</option>
<option value="Tabloid ANSI B Landscape">Tabloid Landscape(PDF)</option>
<option value="Tabloid ANSI B Portrait">Tabloid Portrait(PDF)</option>
</select>
</div>
<div>
<label for="txtCustomHeader">Custom Header</label>
<input id="txtCustomHeader" placeholder="Enter custom Header..." style="width:100%;" />
</div>
<div>
<input id="chkPrintScale" type="checkbox" />
<label for="chkPrintScale">Print to Scale</label>
</div>
<div>
<label for="txtCustomScale">Custom Scale</label>
<input id="txtCustomScale" placeholder="Enter print Scale in inches" style="width:100%;" />
</div>
<div>
<input id="chkPrintLegend" type="checkbox" />
<label for="chkPrintLegend">Print Legend</label>
</div>
<input type="submit" value="Print" id="btnPrint" />
</div>
</div>
</body>
</html>
The problem was that the array I was building considered the numbers as string rather than integer, so I had to use parseInt.
I should have included this code in my original post.  I thought I was misunderstanding the subLayerIds String[] type.
function getPrintLegendLayerPolygons() {
   var arrayLegendPolygons = [], visiblePrintSublayerPolygons = [], arrayValue = [];
   arrayLegendPolygons = getVisibleLayersPolygons().sort();
   if (arrayLegendPolygons.length > 0) {
      for (var i = 0; i < arrayLegendPolygons.length; i++) {
         if (arrayLegendPolygons == indexPoly_CountyBdry || arrayLegendPolygons == indexPoly_MuniBdry ||             arrayLegendPolygons == indexPoly_Waterbody) {
         else {
            visiblePrintSublayerPolygons.push(parseInt(arrayLegendPolygons,10));
      arrayValue = visiblePrintSublayerPolygons;
   else {
      arrayValue = [];
   return arrayValue;
function getVisibleLayersPolygons() {
   visiblePolygons = [];
   $('[name="layerVisibility"]:checked').each(function () {
      if ($(this).is(':checked')) {
         var layerid = $(this).attr('id').split(":");
         // layerid[1] is LayerIndex in the Map Service
         // layerid[3] is service layer (e.g., points, lines, polygons)
         if (layerid[3] == 'Polygons') {
            visiblePolygons.push(layerid[1]);
      } // end if stmt
   return visiblePolygons;
