Story Map Shortlist not deploying
556
06-15-2017 08:20 AM
TownOfGroton
New Contributor III
Hello All!
I created a Shortlist map using "Shortlist Builder Beta", I recently downloaded the application from GitHub (version Storytelling-Shortlist-2.2.3).  I followed the Instructions on GitHub (I added it to my local server and put the appid from the Shortlist Builder Beta site into the index.html file) and I've had this screen for about an hour.  What is going on??
All my maps and data is shared public.
Thanks!
StephenSylvia
Are you running the app from your local server (URL will start with http) or are you running it from the file system (URL will start with file://)? When you are testing the app you will need to run it from the local server. If you are still having issues, can you paste a public URL to your app or send a zip file of the code you are deploying? You can either attach the code to this thread or message me directly through Geonet. We can take a look to see if there are any errors in your code.
TownOfGroton
New Contributor III
Hi Stephen,
I'm testing on local server. Groton Parks
Under Inspect (in Chrome) its showing a "Failed to load resource: the server responded with a status of 404 (Not Found)" error message.
