ArcGIS Pro crashed when perform Calculate Field
2688
14
06-19-2017 07:26 AM
La_OdeAbdul_Hafid1
New Contributor III
I joined a CSV file to a feature class. And when I performed Calculate Field, the PRO crashed.
Any help?
Robert_LeClair
Esri Notable Contributor
La Ode Abdul Hafid - in reviewing this question, is the data you're working on from the Getting to Know ArcGIS Pro from EsriPress?  The screenshot looks like data from a lesson there based upon a support incident I'm seeing.  If so, it is a BUG referenced below:
[#BUG-000104025 : Pro crashes when trying to Calculate Field on a new field in a joined table with data from the Getting to Know ArcGIS Pro EsriPress book.]
The workaround for this issue is to modify the CSV file using the following workflow:
1. Open the referenced household_income.csv file.
2. Locate and modify the record containing the HHINCOME value of “2,500-” to read “2500” instead.
3. Clear the contents of the HHINCOME field for those records containing dashes.
4. Alter the “GEO.id”, “GEO.display-label”, “GEO.id2” column headers to remove the special characters.
6. Save the CSV file and step through the workflow again.  No crash will be encountered.
AdrianWelsh
MVP Honored Contributor
I find it helps that after a join, I export the joined data to a new feature class. Then I can perform field calculations and such. If I work on joined data without exporting it, I oftentimes run into problems. Maybe you should try exporting the joined data, then do field calculations.
La_OdeAbdul_Hafid1
New Contributor III
But can't the workflow (join table - calculate field - unjoin table) be performed, since I found this issue in ArcMap too and the solution is the same?
George_Thompson
Esri Frequent Contributor
Look at the documentation: Fundamentals of field calculations—ArcGIS Pro | ArcGIS Desktop
It is hard to tell by the screenshot, but you are trying to calculate a field in the CSV, correct? If so, that is not supported.
  • The field belongs to a table that has been joined to your table. You can only calculate values for fields in the origin table.
--- George T.
JoshuaBixby
MVP Esteemed Contributor
Even if what he is trying to do isn't supported, which I don't think it is, the application shouldn't crash.  This is a bug if it is reproducible.
George_Thompson
I would agree. laodeabdulhafid13_publisher‌ I would recommend logging a new Esri Technical Support case to have DEV review the crash behavior.
--- George T.
La_OdeAbdul_Hafid1
New Contributor III
Ya. I wonder if it is a bug or because my own PC spec.
La_OdeAbdul_Hafid1
New Contributor III
I am trying to calculate a field in feature class not CSV file..
George_Thompson
Then I would definitely have an analyst take a look at the issue.
--- George T.
KoryKramer
Esri Community Moderator
hafidloa‌ Can you please message me so that we can get your crash dump?
