Workflow for multi year imagery using ArcGIS Pro
698
06-19-2017 11:14 AM
GregJohnson
New Contributor III
Creating a mosaic dataset containing raster data from multiple dates—Help | ArcGIS Desktop is using ArcMap to create this master mosaic dataset of multiple dates. Is there a similar workflow using ArcGIS Pro?
JakeSkinner
Esri Esteemed Contributor
Hi Greg,
The workflow would be the same except the steps will be slightly different for adding the Year field and how you access the service in the section Adding the Service as an Overview.
CodyBenkelman
Greg
Jake is correct, this workflow is essentially the same with Pro.  If you want to dig deeper, start at http://esriurl.com/ImageManagement and look for the link to Preprocessed Orthos at  http://doc.arcgis.com/en/imagery/workflows/managing-preprocessed-orthophotos/overview/
There you will find scripts to allow you to automate creation of your Mosaic Datasets.
Cody B
