GraphicsLayer won't show in Export Web Map Task
488
06-21-2017 07:17 AM
MathieuVillemont
I'm using PrintingTools/Export Web Map task to output my webmap in PDF but my GraphicsLayer won't show up in the map or legend.
"layerDefinition": {
     "name": "pointLayer",
     "geometryType": "esriGeometryPoint",
     "drawingInfo": {
          "renderer": {
               "type": "uniqueValue",
               "field1": "SELECTED",
               "defaultSymbol": {
                    "angle": 0,
                    "xoffset": 0,
                    "yoffset": 0,
                    "type": "esriPMS",
                    "url": "carte/images/map/triangle_16.png",
                    "width": 12,
                    "height": 12
               "uniqueValueInfos": [{
                         "value": "true",
                         "symbol": {
                              "angle": 0,
                              "xoffset": 0,
                              "yoffset": 0,
                              "type": "esriPMS",
                              "url": "map/triangle_16.png",
                              "width": 12,
                              "height": 12
                         "label": "Stock",
                         "description": "Stock"
                         "value": "false",
                         "symbol": {
                              "angle": 0,
                              "xoffset": 0,
                              "yoffset": 0,
                              "type": "esriPMS",
                              "width": 12,
                              "height": 12
                         "label": "Stock",
     "fields": [{
               "name": "SELECTED",
               "type": "esriFieldTypeString"
However if I add another GraphicsLayer with symbol defined for each features instead of in the layerDefinition this works.
I don't see what could be wrong.
