Schema Files Needed to Create File Geodatabase?
533
06-21-2017 08:14 PM
ScottFerguson5
I need to create a File Geodatabase (db) for a customer. I will be using .net. I will populate the db with information and hand the db back to the customer. They will then be able to easily transfer the data in the db I created and populate into their ESRI database.
In order for me to create the database, what are the schema files (or other type of files) that I need to request from the customer so I can create the db that matches their system?
Thanks for any help.
