what is Error (CS1752 Interop type 'PointClass' cannot be embedded. Use the applicable interface instead.)
3955
06-22-2017 11:13 AM
HushamMohamed
I am trying to update my Addin  from ArcObject 10.3 to 10.5 using VS2015  .net 5.2 Frame work  but I am getting  Error
CS1752:  CS1752 Interop type 'PointClass' cannot be embedded. Use the applicable interface instead.)
 // Get selected line segments end points
 pPolyline = pFeature.Shape as IPolyline;
 IPoint pOutPoint = new PointClass();
 // Convert screen coordinates to Map coordinates
 //pPoint = ;
 pMxApp = pApp as IMxApplication;
 pPoint = pMxApp.Display.DisplayTransformation.ToMapPoint(X, Y);
and same Error here as  Well.
//Get normal
 ILine pTangent = new LineClass();
 pPolyline.QueryTangent(esriSegmentExtension.esriExtendTangentAtFrom, FromDist, false, 100.0, pTangent);
I do appreciate any help or hint
Husham
HushamMohamed
Thank you Sean,  I found that just Removing the suffix Class  solve  the Problem..
 IPoint pOutPoint = new Point();
 //pPoint = ;
//Get normal
 ILine pTangent = new Line();
by Anonymous User
Not applicable
Check that Embed Interop Types is set to False for your ESRI assembly references. Its set to True by default when you add them in VS.
HushamMohamed
 //pPoint = ;
//Get normal
