Issue On Rendering Result Of ESRI Request On Graphic Layer
1116
9
06-22-2017 09:57 AM
BehrouzHosseini
Running following code I am able to get JSON result back from a Geometric Network Service on ArcGIS Server but I am having trouble to add the Geometries (Returened graphic) to the graphicsLayerTraceNetworkEdges can you please let me know what I am doing wrong here?
As you can see I already tried both
var graphic = new esri.Graphic(featureSet[i]);
and
var graphic = new esri.Graphic(featureSet[i], symbolTraceNetworkEdges);
but neither of the adding any graphics to the graphicsLayerTraceNetworkEdges
Here is the code I am running
var symbolTraceNetworkEdges = new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 3);
var graphicsLayerTraceNetworkEdges = new esri.layers.GraphicsLayer();
var rendererTraceNetworkEdges = new esri.renderer.SimpleRenderer(symbolTraceNetworkEdges);
graphicsLayerTraceNetworkEdges.setRenderer(rendererTraceNetworkEdges);
graphicsLayerTraceNetworkEdges.setInfoTemplate(infoTemplate);
map.addLayer(graphicsLayerTraceNetworkEdges);
function solve(traceSolverType, params) {
    esri.request({
        url:agsConfig.urlGNUtility(agsConfig.operationalLayers.GNLayer, gn /* id layer from soe*/, traceSolverType /*name of operation SOE */),
        content:params,
        callbackParamName:"callback",
        load:function (result) {
            graphicsLayerTraceNetworkEdges.clear();
             var resultFeatures = result.edges;
             console.log(resultFeatures);
             for (var j = 0, jl = resultFeatures.length; j < jl; j++) {
                  var featureSet = resultFeatures[j].features;
                   for (var i = 0, il = featureSet.length; i < il; i++) {
                      //var graphic = new esri.Graphic(featureSet);
                      graphicsLayerTraceNetworkEdges.add(graphic);
ThomasSolow
Occasional Contributor III
in your sample code, you have a variable called params that you're passing in to esri.request.  Try adding a key: "outSR" and value: 4326 to params (I assume it's a javascript object).
ThomasSolow
Can you show an example of what featureSet looks like?
BehrouzHosseini
Thanks for reply Thomas, Please take a look at post Attachment. I just uploaded a sample return (data.json) on  `console.log(JSON.stringify(featureSet));`
       // var graphic = new Graphic(evt.geometry, config.symbolPointEBarrier);
       //var graphic = new Graphic(featureSet);
ThomasSolow
Okay, I think you should create a SimpleRenderer using the symbol you're creating and pass that renderer in to the graphic layer constructor.  This will take care of the symbology for each graphic on the layer.  In the graphic constructor, use:
Also, what's the spatial reference on your map?  There may be a spatial reference issue here as well.  It looks like your data uses web mercator x, y.  I notice that, in your feature JSON, there is no spatial reference property.  Something might be going with that as well.  You should check the spatial reference of a graphic after you use the esri.Graphic constructor and see what spatial reference is being assigned.
BehrouzHosseini
You are right Thomas,
Seems I am having issue with spatial reference!
Can you please let me know how I can force to receive the data in the correct spatial reference format?
ThomasSolow
You may be able to specify the outSR (out spatial reference)  in the request that you make for features.  Try adding an { outSR: 4326 } key-value pair to your params object.
BehrouzHosseini
I am kinda confused! where should I add the outSR: 4326?
ThomasSolow
BehrouzHosseini
You are a Rock! Thanks a lots!
BehrouzHosseini
Here also is a single format of each featureSet
      "attributes":{
         "OBJECTID":1247
      "geometry":{
         "paths":[
                  1034476.7734464034,
                  1870179.847935468
                  1034476.6261717044,
                  1870189.4210841134
