Unable to scroll quickly through widgets in Launchpad theme dock
825
06-23-2017 04:33 AM
JosephDavies
New Contributor III
It seems that I am unable to quickly scroll through the widgets of my application in the "docker" section using the "nextBtn" and "previousBtn" elements of the Launchpad theme in WAB 2.1.
If you scroll slowly, allowing time for the animation to finish, it works fine, but if you wish to scroll rapidly, it sort of cancels the animation and slows down the whole process.
I understand that this is a fairly trivial issue, but nonetheless it is quite uncomfortable if you have a lot of widgets, and need to quickly access a widget towards the far right of the docker.
Does anyone have a fix for this?
RobertScheitlin__GISP
Joseph,
   Have you checked the 2.4 version to see if it still has that issue?
JosephDavies
New Contributor III
Hi Robert,
   I just upgraded to 2.4 and the issue is still there.
