Failed to Open Grahics Server
1399
06-25-2017 04:52 PM
JohnMosheim
I have installed 10.5 desktop single use, using Windows 7 Professional, installed in the X86 programs folder, the classify function is not working I get the ArcGIS message "Failed to Open Graphics Server". I uninstalled and installed the software twice, spent 3 hrs with ESRI tech support and tried everything and still not able to fix. The windows file that is associated with the graphics server is present in the x86 program files folder. I have no clue how to fix this thing...any ideas?
John
GreeshmaVyshnav
I had this same issue with arcmap 10.1.
firstly you need to check for GSW files in windows/syswow64. If found try running exe file to see the problem. In my case I was missing ltfil13n.dll, ltkrn13n.dll,ltefx13n.dll and Ltdis13n.dll files in windows/syswow64 and windows/system32 folders.
i just downloaded it and pasted those files to both folders and restarted .
this solved entire issues.
