Lambert Conical Orthomorphic
1602
5
07-01-2017 06:26 AM
DavidOrchard
I am trying to digitize an old map. The projection is Lambert Conical Orthomorphic, It is a southern hemisphere map
I  georeference the map (it is a scanned image, I've tried various projections) it appears to georeferecnce OK. But when I try to digitize various features as a layer, the digitised vector layers are (flipped over and spun thru 180 degrees). Advice desperately wanted,  Anyone have any ideas?
thanks
DanPatterson_Retired
How did you georeferenced it? and was latitude specified as negative? Longitude details?
Any specification would help
MKennedy-esristaff‌ this may be for you
DavidOrchard
Thanks Dan for swift response, I set +ve latitude for Southern Hemisphere,  my error
MelitaKennedy
Esri Notable Contributor
Just double-checking--you're good?
Melita, David had the latitudes flipped
DavidOrchard
Yes Melita, I'm sorted, simple error, my mistake, thanks for checking
