Labeling Point Graphics
1838
8
07-10-2017 10:26 PM
MuhammadFayaz
I am trying to label graphics that is returned by a query task as points but could not success. Anyone can please help. here is my code:
function zoompnt() {
require(["dojo/parser", "esri/layers/LabelClass", 'esri/layers/LabelLayer',"esri/renderers/SimpleRenderer", "dojo/promise/all", "dojo/_base/connect", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
"esri/Color", "dojo/_base/array", "dojo/dom", "esri/symbols/TextSymbol","esri/InfoTemplate",
"esri/config", "esri/map", "esri/geometry/Extent", "esri/layers/FeatureLayer",
"esri/symbols/SimpleFillSymbol", "esri/layers/ArcGISDynamicMapServiceLayer",
"esri/tasks/query", "esri/tasks/QueryTask","esri/layers/GraphicsLayer",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dojo/domReady!"], function (parser,LabelClass,LabelLayer,SimpleRenderer, all, connect, SimpleMarkerSymbol, SimpleLineSymbol,
Color, arrayUtils, dom,TextSymbol,InfoTemplate,
esriConfig, Map, Extent,FeatureLayer,
SimpleFillSymbol, ArcGISDynamicMapServiceLayer,
Query, QueryTask, GraphicsLayer) {
var queryLayer = "http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/21";
var fir, sec;
var graLayer;
var labels;
var selFeatureLayer;
fir = document.getElementById("DropDownList2").value;
sec = document.getElementById("DropDownList3").value;
var qTask = new QueryTask("http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/21");
var query = new Query();
query.where = "SUBDIV_NO LIKE '%" + fir + "%' AND PARCEL_NO LIKE '" + sec + "'";
query.outFields = ["*"];
query.returnGeometry = true;
qTask.execute(query, function (featureset) {
var selSymbol = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_DIAMOND).setColor(new Color([255, 0, 0, 0.5]));
var selSymbol1 = new SimpleMarkerSymbol().setStyle(SimpleMarkerSymbol.STYLE_DIAMOND).setColor(new Color([255, 5, 5, 5.5]));
// create a text symbol to define the style of labels
var textColor = new Color("#666");
var textLabel = new TextSymbol().setColor(textColor);
textLabel.font.setSize("8pt");
textLabel.font.setFamily("arial");
textLabelRenderer = new SimpleRenderer(textLabel);
labels = new LabelLayer({
var gra = "";
var i;
for (i = 0; i < featureset.features.length; i++) {
gra = featureset.features;
gra.setSymbol(selSymbol1);
map.graphics.add(gra);
graLayer = new GraphicsLayer();
var infoTemplate = new InfoTemplate("Serial_No", "District Name:${PARCEL_NO}");
graLayer.setInfoTemplate(infoTemplate);
graLayer.add(gra);
map.addLayer(graLayer);
labels.addFeatureLayer(graLayer, textLabelRenderer, "${PARCEL_NO}");
map.addLayer(labels);
gra++;
RobertScheitlin__GISP
Muhammed,
   You are trying to use a GraphicsLayer (GL) when the LabelLayer is expecting a FeatureLayer (FL). Also you are adding your Graphics Layer inside your loop which means you are adding many GLs (not correct). Here is your code changed to use a FL instead.
  require(["dojo/parser", "esri/layers/LabelClass", 'esri/layers/LabelLayer', "esri/renderers/SimpleRenderer", "dojo/promise/all", "dojo/_base/connect", "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
    "esri/Color", "dojo/_base/array", "dojo/dom", "esri/symbols/TextSymbol", "esri/InfoTemplate",
    "esri/tasks/query", "esri/tasks/QueryTask", "esri/layers/GraphicsLayer",
    "dojo/domReady!"
  ], function(parser, LabelClass, LabelLayer, SimpleRenderer, all, connect, SimpleMarkerSymbol, SimpleLineSymbol,
    Color, arrayUtils, dom, TextSymbol, InfoTemplate,
    esriConfig, Map, Extent, FeatureLayer,
    var labelLayerUrl = "http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/21";
    var fir, sec, graLayer, labels, selFeatureLayer;
    var labelLayer = new FeatureLayer(labelLayerUrl, {
      outFields: ["*"],
      opacity: 0,
      mode: FeatureLayer.MODE_ONDEMAND
    labelLayer.setDefinitionExpression(query.where);
    map.addLayer(labelLayer);
    qTask.execute(query, function(featureset) {
      if(map.getLayer("labels")){
        map.removeLayer(map.getLayer("labels"));
      var gra, i;
      for(i = 0; i < featureset.features.length; i++) {
        gra = featureset.features[i];
        graLayer.add(gra);
      labels.addFeatureLayer(labelLayer, textLabelRenderer, "${PARCEL_NO}");
      map.addLayers([graLayer, labels]);
MuhammadFayaz
Thank you Robert for you help and guide But still it don't show label for the points. Bellow is the result..
Muhammad,
   I would have to see your full code.
MuhammadFayaz1
Dear Robert,
Please check the bellow links for full code. Please let me know if you need the server IP.
Thank you
html
javascript
Muhammad,
   Here is your code cleaned and legacy style coding removed. See if this helps.
HTML:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head id="Head1">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Parcel zoom</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.20/esri/css/esri.css" />
  <script src="http://js.arcgis.com/3.20/"></script>
  <style>
    #map {
      height: 50%;
      width: 50%;
      margin: 0;
      padding: 0;
  </style>
  <script type="text/jscript" src="JScript.js"></script>
  <style type="text/css">
    #Coordinates {
      top: -3px;
      right: -206px;
    tr.spaceUnder>td {
      padding-bottom: 1em;
    .style14 {
      width: 93px;
      text-align: right;
  </style>
</head>
<body>
  <form id="form1">
    <table dir="RTL" align="right" cellspacing="10">
      <tr>
        <td width="200px" colspan=2>
          <b>حدد الموقع من خلال القائمة المنسدلة</b>
        </td>
        <td dir="RTL" width="100px" align="right">
          <b></b>
        </td>
        <td width="100px" align="right"> </td>
          <b></b>
        </td>
      </tr>
      <tr>
        <td class="style14">
          <b>اختر منطقة   :</b></td>
        <td colspan="5" width="100px">
          <b><select id="DropDownList1"  class=""></select></b>
        </td>
      </tr>
      <tr>
        <td dir="RTL" width="100px">
          <b><label id="lblDropDownList2" >اختيار المخطط :</label></b>
        </td>
          <b></b>
          <select id="DropDownList2" class=""></select>
        </td>
      </tr>
      <tr>
          <b><label id="lblDropDownList3" >اختيار القطعة :</label></b>
        </td>
          <b></b>
          <select id="DropDownList3" class=""></select>
        </td>
      </tr>
      <tr>
        <td colspan="6">
          <div id="map" style="width:800px;height:400px; margin:0 auto;">
          </div>
        </td>
      </tr>
    </table>
  </form>
</body>
</html>
JScript.js:
var map;
require(["dojo/parser", "dojo/on", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/SpatialReference",
  "esri/Color", "dojo/_base/array", "dojo/dom", "esri/geometry/Point", "esri/layers/FeatureLayer", "esri/layers/GraphicsLayer",
  "esri/map", "esri/geometry/Extent", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/renderers/SimpleRenderer",
  "esri/tasks/query", "esri/tasks/QueryTask", "esri/symbols/TextSymbol", "esri/InfoTemplate", "esri/layers/LabelLayer",
  "dojo/domReady!"
], function(parser, on, SimpleFillSymbol, SimpleLineSymbol, SpatialReference,
  Color, arrayUtils, dom, Point, FeatureLayer, GraphicsLayer,
  Map, Extent, ArcGISDynamicMapServiceLayer, SimpleRenderer,
  Query, QueryTask, TextSymbol, InfoTemplate, LabelLayer) {
  parser.parse();
  map = new Map("map", {
    slider: false,
    showLabels: true,
    logo: false
  dom.byId('DropDownList2').style.display = 'none';
  dom.byId('DropDownList3').style.display = 'none';
  dom.byId('lblDropDownList2').style.display = 'none';
  dom.byId('lblDropDownList3').style.display = 'none';
  on(dom.byId('DropDownList3'), "change", zoom);
  on(dom.byId('DropDownList3'), "change", zoompnt);
  on(dom.byId('DropDownList2'), "change", zoom2);
  on(dom.byId('DropDownList1'), "change", zoom1);
  //imagery is the ArcGIS Online imagery
  //var imagery = new ArcGISTiledMapServiceLayer("http://00.000.00.00:8399/arcgis/rest/services/Explorer_Qassim_Map/MapServer", { id: "imagery" });
  var imagery = new ArcGISDynamicMapServiceLayer("http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer", {
  map.addLayer(imagery);
  //var opr = new ArcGISTiledMapServiceLayer("http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer");
  //map.addLayer(opr);
  var point = new Point([397867.7369, 2912284.0917], new SpatialReference({
    wkid: 32638
  map.centerAndZoom(point, 9);
  var daySelect = dom.byId('DropDownList1');
  daySelect.options[0] = new Option("select", 0);
  var qTask = new QueryTask("http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/14");
  query.where = "1=1";
  query.outFields = ["DS_NAME_D,DS_NAME"];
  query.returnGeometry = false;
      daySelect.options[daySelect.options.length] = new Option(featureset.features[i].attributes.DS_NAME, featureset.features[i].attributes.DS_NAME_D);
  function removeOptions(selectbox) {
    var i;
    for(i = selectbox.options.length - 1; i >= 0; i--) {
      selectbox.remove(i);
  function zoom() {
    var queryLayer = "http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/20";
    var fir, sec;
    fir = dom.byId("DropDownList2").value;
    sec = dom.byId("DropDownList3").value;
    var qTask = new QueryTask("http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/20");
      map.graphics.clear();
      var selectedRequest = featureset.features[0].geometry;
      var selSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 0, 255]), 4.5), new Color([255, 255, 0, 0.25]));
      var gra = featureset.features[0];
      gra.setSymbol(selSymbol);
      var ext = selectedRequest.getExtent();
      map.setExtent(ext.getExtent().expand(2));
      outFields: ["*"],
      opacity: 0,
      if(map.getLayer("labels")) {
      var gra, i;
        graLayer.add(gra);
  function zoom1() {
    var queryLayer = "http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/14";
    var fir;
    fir = dom.byId("DropDownList1").value;
    query.where = "DS_NAME_D = " + fir + "";
      dom.byId('DropDownList2').style.display = 'block';
      dom.byId('lblDropDownList2').style.display = 'block';
      var daySelect = dom.byId('DropDownList2');
      removeOptions(dom.byId("DropDownList2"));
      query.where = "DISTRICT_NAME_D = " + fir + "";
      query.outFields = ["SUBDIV_NO"];
      query.returnDistinctValues = true;
          daySelect.options[daySelect.options.length] = new Option(featureset.features[i].attributes.SUBDIV_NO, featureset.features[i].attributes.SUBDIV_NO);
  function zoom2() {
    var queryLayer = "http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/13";
    var fir;
    var qTask = new QueryTask("http://00.000.00.00:6080/arcgis/rest/services/Operational_Test/MapServer/13");
    query.where = "SUBDIV_NO LIKE '%" + fir + "%'";
      dom.byId('DropDownList3').style.display = 'block';
      dom.byId('lblDropDownList3').style.display = 'block';
      var daySelect = dom.byId('DropDownList3');
      removeOptions(dom.byId("DropDownList3"));
      query.where = "SUBDIV_NO LIKE '%" + dom.byId("DropDownList2").value + "%'";
      query.outFields = ["PARCEL_NO"];
        //map.graphics.clear();
          daySelect.options[daySelect.options.length] = new Option(featureset.features[i].attributes.PARCEL_NO, featureset.features[i].attributes.PARCEL_NO);
  function zoom_di(di) {
    var fir;
    fir = di;
  function zoom_SIDI(si, pi) {
    var fir, sec;
    fir = si;
    sec = pi;
  function zoom_SI(si) {
    var fir;
    fir = si;
MuhammadFayaz
Dear Robert,
I still could not manage to label the points. Can you please review it once for me?? i really appreciate your help!
Muhammad,
   Here is your code working using LabelClass instead of the depreciated LabelLayer:
var map;
  "esri/tasks/query", "esri/tasks/QueryTask", "esri/symbols/TextSymbol", "esri/InfoTemplate", "esri/layers/LabelClass",
  "esri/symbols/SimpleMarkerSymbol", "esri/symbols/Font",
  "dojo/domReady!"
  Query, QueryTask, TextSymbol, InfoTemplate, LabelClass, SimpleMarkerSymbol, Font) {
  parser.parse();
    slider: false,
    showLabels: true,
    logo: false
  var imagery = new ArcGISDynamicMapServiceLayer("http://84.235.15.69:6080/arcgis/rest/services/Operational/MapServer", {
    wkid: 32638
  var qTask = new QueryTask("http://84.235.15.69:6080/arcgis/rest/services/Operational/MapServer/14");
    var i;
  function zoom() {
    var queryLayer = "http://84.235.15.69:6080/arcgis/rest/services/Operational/MapServer/12";
    var fir, sec;
    var qTask = new QueryTask("http://84.235.15.69:6080/arcgis/rest/services/Operational/MapServer/12");
    var labelLayerUrl = "http://84.235.15.69:6080/arcgis/rest/services/Operational/MapServer/12";
      outFields: ["*"],
      opacity: 0,
      var selSymbol1 = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_DIAMOND,10,null,new Color([255, 5, 5, 5.5]));
      var textLabel = new TextSymbol({
        font: new Font("16", Font.STYLE_NORMAL, Font.VARIANT_NORMAL, Font.WEIGHT_BOLD, "Helvetica"),
        color: new Color("red")
      var gra, i;
        graLayer.add(gra);
      var json = {
        "labelExpressionInfo": {"value": "{PARCEL_NO}"},
        "useCodedValues": true
      var lc = new LabelClass(json);
      lc.symbol = textLabel;
      labelLayer.setLabelingInfo([lc]);
      map.addLayers([graLayer]);
  function zoom1() {
    var queryLayer = "http://84.235.15.69:6080/arcgis/rest/services/Operational/MapServer/14";
    var fir;
  function zoom2() {
    var queryLayer = "http://84.235.15.69:6080/arcgis/rest/services/Operational/MapServer/13";
    var fir;
    var qTask = new QueryTask("http://84.235.15.69:6080/arcgis/rest/services/Operational/MapServer/13");
    var fir;
    fir = di;
    var fir, sec;
    fir = si;
    sec = pi;
    var fir;
    fir = si;
MuhammadFayaz
Dear Robert,
Thank you very much. I reason i was unable to see the labels was because of the scale dependency on the server side.
