Anselin Local Moran's I - Scatter Plot
2299
07-14-2017 07:21 AM
ChristopherJodice
HI Everyone - When using the Anselin Local Morans I tool under Spatial Statistics Tool->Mapping Cluster ,  I am wanting to see the Scatter Plot of the z_i vs Lag z_i  ... however I don't see this chart - I would create it but I don't see a table that has the underlying values.  Does this tool create such chart?  Any help is appreciated.
Chris
JenoraD_Acosta
The tool output does include z_i for each feature, but not the Lag z_i (this would be a nice enhancement and I will bring it up with the team.)  You can calculate the average for each neighborhood by:
- Create a .swm file (Generate Spatial Weights Matrix) with the neighborhood relationships
- Convert the Spatial Weights Matrix to Table
- Then you can join this table to the feature class based on the neighbor ID
- Then the neighborhood averages can be summarized (Summary Statistics) and averaged based on each feature's original ID
Hope this helps,
Jenora
JenoraD_Acosta
Hope this helps,
Jenora
ChristopherJodice
Thank you so much!
What you explain below is what I was as a work-around
Christopher Jodice
Work : 973.921.5611
ChristopherJodice
Hi Jenora,
The Neighbor ID (NID) can be mapped back to the feature class with what field in the feature class? Is it ObjectID = NID ?? Or FID=NID ?
Christopher Jodice
Work : 973.921.5611
