ArcGIS 10 (Desktop) not displaying CSV datapoint
1604
6
07-14-2017 08:16 AM
CalumAH
Hi all,
I can't seem to get the attached CSV data points (which are Decimal Degree coordinates) to display on my map file (also attached). I've tried playing around with the long/lat columns, changing the projected system, and all to no avail. Really quite stuck now, so would be very grateful for some clarity as to where I'm going wrong.
Thanks!
Calum
AbdullahAnter
Occasional Contributor III
I tried your data. and I have not any problem.
CalumAH
Hi Abdullah,
Thanks for the quick reply, and it's encouraging that you've got it working! I'm trying to display the points on top of the 'OA' layer in the main file (OAs are geographic areas, these ones focused on London). Are you able to do this at all? I've followed numerous tutorials, but without success, so I'd be really grateful if you could walk through how to do this.
Thanks again!
Calum
AbdullahAnter
After you add points layer and define its spatial reference well, use  Project—Help | ArcGIS Desktop tool for  this layer to be same the 'OA' layer projection  .
CalumAH
Hi abdallah_91@yahoo.com
Apologies for my delay in replying. Unfortunately, this still isn't working. In terms of what I've done, I have:
1) Imported the geographic entity (here, OA layer)
2) Added data (XY data) and defined the Long/Lat
3) Ensured that the projections are the same (using the Project tool)
However, the data does not display at all. What else could be happening here?
Thanks again for all of your help! It's really appreciated.
Calum
AbdullahAnter
could you insert pictures for this problem?
MelitaKennedy
Esri Notable Contributor
Hi Calum,
When you added the xy data, you set the coordinate system to OSGB36? Or WGS 1984?
Ah, the longitude and latitude fields in the csv files are swapped. The -1 values should be labeled longitude and the 51 values are the latitude values.
If the OA data is really in British National Grid, you should set a transformation. Open data frame properties, coordinate system tab, transformations button.
Melita
