Greetings...
I am an occassional arcmap user. Mainly working with shape files. I have received a mdb file from a client. I do not know how to get this file into arcmap. I was hoping it was just a drag and drop from the catalog, but that didn't work. I'd appreciate any guidance on this. Thanks.
MKH
What version of ArcGIS are you using? Did you try using the 'Add Data' button?
using 10.3.1
used the add data button. got this message . Tables show up in the table of contents, but no data in the map.
Hi Mike are you using ArcGIS Desktop Basic?
Esri Support published this technical article. Their solution is that you would need to upgrade to either ArcGIS Desktop Standard (ArcEditor) or ArcGIS Desktop Advanced (ArcInfo)
If you are still unable to add the data, could you expand the MDB (to see its content) in ArcCatalog, and send a screenshot? Or better, if you could zip the MDB and share with me for testing @ joypoddar.87@gmail.com
sent
The MDB file looks like a simple access file, and not a Personal Geodatabase. So, there is no spatial data.
Also I couldn't find any field containing Lat./Lon. values which could have been mapped. Maybe you will need to go back to your client for shapefiles/Geodatabase/Lat./Lon. values.
NOTE: ArcMap reads Personal Geodatabase, not an MS Access File, although both have MDB extension.
For clarify , that error because you add geodatabase file in arc map , but you shoud open geodatabse inside the browse window and add the feature class of geodatabase. not all geodatabase.
