the map in my form displays coordinates in Degrees Minutes, ie 30^degrees 41', Can you change the way the coordinate system is displayed on the map?
555
07-17-2017 09:30 AM
SLouq
by MVP Regular Contributor
JamesTedrick
Esri Esteemed Contributor
This can be set in Survey123Connect in the Settings > Map area:
JamesTedrick
SLouq
Thanks James!
