https://MyEsriUrl/arcgis/rest/services?f=sitemap doesn't work
628
07-19-2017 06:40 AM
DavidWendelken
I have some code that queries the esri webserver for a list of services.
I start off with:
That code worked for years.
We recently attached a portal to our esri webserver. We're now running v10.5 of both.
Now, the esri admin can issue this command in the browser and it still works, but if I issue it I get an empty list back.
I thought it might be a permissions issue except for three facts:
(1) If I go to
I can see everything I ought to see.
(2) I've found out that I can now use
https://MyEsriUrl/arcgis/rest/services?f=json
and that also works correctly.
(3) Esri admin added me to the esri admin role and I still can't see anything with ?f=sitemap.
Obviously, I can rewrite the code to work, but that app is scheduled to be replaced and I would rather spend time working on the replacement app...
Any ideas on how to get ?f=sitemap to work properly?
Tags (1)
DavidWendelken
arcgis server - esri rest service ?f=sitemap returns no services - Geographic Information Systems St... covers this in more detail.
Apparently, this is intended behavior.   Can't understand why, but it is what it is.
DavidWendelken
Item #3 above was a browser caching issue.  So at least I'm getting consistent results.
Any ideas how to get ?f=sitemap to work for someone who isn't a site admin?
DavidWendelken
DavidWendelken
I've rewritten my code to make multiple, recursive calls to the server via the ?f=json and it's slow as all get out.   Yuck!
So, I'm going to create a service acct with GIS admin privs and create a web service to wrap the call to the ?f=sitemap option.   That way, the web service will ask as an admin and pass the data I need back much faster.
For gis websites that aren't "ours" (so we don't have admin access), we'll use the new code I've written.
