Constistent Color acrsoss maps
439
07-21-2017 01:26 PM
Maria_CristinaLara
I  have about 20 layers in my map document and I'd like to autamatically assign color values to them quickly - such that when I make the same kind of map again I use the same 20 colors in the same order without having to manually change them. Is that Possible?
Tags (1)
JohnPlunkett
If you have a constant attribute that you are basing the symbology on - you could create a layer file and then import the symbology for each one
Saving layers and layer packages—Help | ArcGIS Desktop
Importing symbology from another layer—Help | ArcGIS Desktop
John P
