two shapefiles won't show on map at the same time
1212
07-21-2017 07:23 AM
RickCheney
Occasional Contributor III
I have two shapefiles, polygons, representing adjacent areas on a map, if I Zoom to Layer on either layer, that layer will show on the map but the other layer will not.
Both shapefile  have:
Projected Coordinate System:  NAD_1983_UTM_Zone_15N
Projection:  Transverse_Mercator
Geographic Coordinate System:   GCS_North_American_1983
Datum:  D_North_American_1983
I may have "projected" one of the shapefiles and may have projected it incorrectly.  Does anybody have any idea what is wrong here?  Or how I can fix it?
AbdullahAnter
Check the layers position using correct base map.
Make sure that layers are it the top in TOC.
RickCheney
Thanks Abdullah, I checked the things you mentioned and they were ok.  I think one or both of the files were corrupted.  Fortunately I was able to replace the files and the new files displayed fine.
AbdullahAnter
So my answer not the solution.
Could you mark your answer is correct for this question if you are sure the files were corrupted ?
or let your question open by remove the mark correct answer to get more helpful answers.
