Feature Class losing edits and acting strange...
509
07-25-2017 02:21 PM
BrettBlankner
 We're having editing issues with a feature class in our SQL SDE, it seems to shift after edits have been made from one day to the next.  There is also an issue that when both Venessa and I are looking at the same area on separate screens we will see two totally different things in the same area of interest. What could be the cause of this and what we can do to fix this??
Tags (3)
ChrisDonohue__GISP
Can you provide some more background on what systems you have and what your processes are.  That will help folks in analyzing this:
  • What version of SQL is being used?
  • What version of ArcGIS is that tied to?
  • Is the system set up to directly edit Default?
  • Are there any nightly processes that run that would affect that dataset, like for example a scheduled Reconcile of all versions?
Chris Donohue, GISP
BrettBlankner
Good point.  We are running:
  • SQL 2012 R2
  • ArcGIS Desktop 10.3.1
  • Yes, edits to Default
  • Two nightly processes.  One is the compression.  Another is exports of the feature classes to shapefiles as a backup.
Thanks!
