iOS Closest Facilities Example
413
07-27-2017 01:50 AM
VictorGallego1
Hello!
I am not able to do an functional example of closest facility in ios.
Someone who has solved it?
MarkDostal
Thank you for your question.  Using the AGSClosestFaciltyTask is very similar to the other task-based APIs, such as the AGSRouteTask (routing) or the AGSLocatorTask (geocoding).  Samples for those can be found in the ArcGIS Runtime Samples app for iOS:  GitHub - Esri/arcgis-runtime-samples-ios: Swift samples demonstrating various capabilities of ArcGIS...
Specifically, for routing:
arcgis-runtime-samples-ios/FindRouteViewController.swift at master · Esri/arcgis-runtime-samples-ios...
And for geocoding:
arcgis-runtime-samples-ios/FindAddressViewController.swift at master · Esri/arcgis-runtime-samples-i...
If those don't help, please post the code you're having problems with and I'll take a look.
Cheers,
Mark
