How do I create a smaller buffer using an existing larger one?
2019
07-27-2017 05:33 AM
EllenWildig
New Contributor III
I have a 250m buffer, which was generated from a line. However, I no longer have access to the line shapefile and now need a 50m buffer. Is there a way to use the 250m buffer to generate a smaller one?
JayantaPoddar
MVP Esteemed Contributor
You could create Negative Buffer. Consider it as buffer of a polygon (buffer_polygon).
When buffering polygon features, negative buffer distances can be used to create buffers inside the polygon features. Using a negative buffer distance will reduce the polygons' boundaries by the distance specified.
Caution:
If the negative buffer distance is large enough to collapse the polygon to nothing, a null geometry will be generated. A warning message will be given, and any null geometry features will not be written to the output feature class.
Buffer—Help | ArcGIS for Desktop
Think Location
JayantaPoddar
Caution:
Think Location
EllenWildig
New Contributor III
Thanks for the tip. Can't believe I didn't think to test a negative number in the box. It works perfectly, however unfortunately the scheme is quite complicated so the resulting buffer is a little odd...
JayantaPoddar
I expected that. It would be tough to buffer bends (finer bends). But that is the best workaround we have (at least for me).
Think Location
