chloropleth
666
08-02-2017 09:49 AM
HansStroo
I want to make a chloropleth map of US counties. 1) Can you make chloropleth maps using ARCgis Online, or only in the desktop version? 2) Can you put other layers (e.g. railroads & waterways) on top of the chloropleth layer?
AdrianWelsh
MVP Honored Contributor
Hi Hans,
Yes you can do the things you would like to do in ArcGIS Online‌. Can you give more details as to how you want to use a choropleth map in AGOL?
Here are some ways to style data in AGOL
Change style—ArcGIS Online Help | ArcGIS
(check here too:
http://doc.arcgis.com/en/arcgis-online/create-maps/styling-reference.htm#ESRI_SECTION1_E3130A70037C4... )
Here is a real brief example(s) of a choropleth map in AGOL:
http://jmu.maps.arcgis.com/apps/View/index.html?appid=85d3231789a64bb4a7d890a9a0a322ce
https://www.arcgis.com/home/webmap/viewer.html?webmap=9e745fb87d16465a80d193131b1442dc
JayantaPoddar
MVP Esteemed Contributor
Found a guide for creating Choropleth Map in ArcGIS Online http://cgge.aag.org/Migration1e/CaseStudy6_Japan_Feb13/ArcGIS_Online_Guide.pdf . A few functionalities could have changed since then.
Think Location
